Fried
- Aug 10, 2015
- Italy
if you mean fps I only changed bitrate resolution for 1920x1080 60fps, for other I found 30 and 24 fps on bitrate table1080p 30p 25p 24p also ? i using PAL
I read lukasz354 answer so I made custom firmware for him...NON L VERSIONZ22
Here you are 1.2.10 firmware rev.22L customized with 1080p 60fps & 720p 120fps both 35Mbps ......Hello Guys, I have the Z22L version and 1.2.10 firmware.
I have also use the autoexec for 1.2.0 firmware, but I think that the bitrate don't run properly, because when i read on my video information, the bitrate is writed as "23000 kbps" and not 35Mbps....
My microsd cards is a 32GB Professional microSDHC UHS-II.
thanks what is the mbps of 30fps as i dont use 60/120fps thanksI read lukasz354 answer so I made custom firmware for him...
There you go https://drive.google.com/file/d/0BxO_QexYT9EATDRHVjhicXU5Y0k/view?usp=sharing
firmware 1.2.10 Z22 customized with 1080p 60fps and 720p 120fps both 35Mbps... Enjoy...
For 1080p 30fps is set to 18Mbps default.thanks what is the mbps of 30fps as i dont use 60/120fps thanks
Hy!For 1080p 30fps is set to 18Mbps default.
In this one I set 1080p and 720p 30fps both 35Mbps...
https://drive.google.com/file/d/0BxO_QexYT9EAOE5LdURLS0F4WkU/view?usp=sharing
Already read this issue by another guy that used script, personally I don't know if is a card limit or something else, original firmware come with 25mbps by default for high quality , 15mbps medium and 12mbps low quality, also if your card doesn't support that speed and would drop quality it should dropped to 15mbps not 21??Hy!
I downloaded your firmware and installed it.
As I was trying the new cfw, I saw that my cam (22 version) only records a couple of seconds (1. try- 38s, 2. try 18s) with 35MBP/s and then makes a new file, but with 21MBP/s, this file as I saw can be longer than 5 minutes.
info, maybe it is useful: I am using Samsung class 10 32gb memory card, maybe not the fastest one..
If it works like this I would appreciate a fw with lower bitrate, maybe 25MBP/s on 1080p 30fps, or the original one.
What should I do?
Thanks in advance!
Thank you for thisI read lukasz354 answer so I made custom firmware for him...
Work great thanks, but @35mbps is only available for 1080p 60fps and 720p 120fps, like you mention itI read lukasz354 answer so I made custom firmware for him...
Sure, for 240fps in custom firmware I can only reach 432x240 resolution for the others : 640x480 and 848x480 you need to do it via script...Could you create a firmware which has increased bitrate for 1080p60 as well as 720p120 and [xxx]p240? for 23S? Thanks
There you go, in this custom 23L firmware all High Quality for all resolution are changed to 35Mbps, medium and low quality come with default bitrate.
Enjoy!...
https://drive.google.com/file/d/0BxO_QexYT9EAdmxLRy1kZW0yQlE/view?usp=sharing
