Hi guys,
im a newbie with action cameras, im looking for some info about this cam, xiaomi yi cam is supporting exfat fs ? if its not, thet it means i cant record videos larger than 4gig. Can someone give me an answer with this ?
Thank you.
Confirmed lines No.9~11 belongs to 1920*1080p@60fps
I've test on my 16GB 300x class-10 micro sd card, lost approx 2 seconds during saving videos between 2 files.
So using 50Mbps, must need a high speed memory card.
@luckylz
Thank you for answer!
is gopro hero also same ? or any other brand ? Actually i dont like idea of segmented video files. But its given with these prices though...
I really appreciate the work on that firmware. Would it be possible to still choose between low/medium/high quality (right now the modded firmware will always use 35mbps)?
For example the 1080p Mode with 24/25/30 fps would work perfect for me with low = 12mbps, medium = 20mbps, high = 30mps or something like that.
I recognized some little compression artifacts when using the default firmware with 12mbps in the 1080p / 25fps mode, but with 30mbps not only do those artifacts disappear, it is even more bitrate than i would need in that mode and it will produce large files.
So it would be very handy if I could cycle between some bitrate modes by selecting low/medium/high quality in the app.
Thanks for the link.
I remember that after increasing the bitrate camera was creating small files instead of 5 minutes clips, for example. Maybe was card problem but at that time bitrate cannot be increased too much, maybe 5mbps.a question to the xiaomi users.
can a developer do a sjcam 5000+ version 2.1 with a higher bitrate
i would do it for my self but i dont know which line is to change in the tool for all formates
