I think it's better if I set the bitrate higher in the bitrate table it self. Does anyone know what number in the table the 2k resolution is designated? I am currently uaing a a beta firmware with 2k resolution but it's only set to 12Mbit.
![SnvSKei.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FSnvSKei.jpg&hash=a843e95446908e9e372535a12df37181)
C05C3016 from 1.2.10 firmwareI think it's better if I set the bitrate higher in the bitrate table it self. Does anyone know what number in the table the 2k resolution is designated? I am currently uaing a a beta firmware with 2k resolution but it's only set to 12Mbit.
6 2304 1296 29,97I think it's better if I set the bitrate higher in the bitrate table it self. Does anyone know what number in the table the 2k resolution is designated? I am currently uaing a a beta firmware with 2k resolution but it's only set to 12Mbit.
yeah, but also for 1.2.11 debug2?? intoi has that firmware
I don't get what you mean, you want to make a script or firmware custom?Could anyone help me by create a code for 720p,120fps,35Mbps ('old' firmware 1.2.10)
I found from funnel that list, but are not able to covert it.
Width Height Fps Default bitrate
156 1280 720 119,88 4190
157 1280 720 119,88 4170
158 1280 720 119,88 4140
NowWhat script did you try and describe what your mean when you say "doesn't work".
it works, but if I will change bitrate option in the YIMAX-MOVIE?What script did you try and describe what your mean when you say "doesn't work".
Hi Guys, I would like to know what all the fuss and bother is about the 2304x1296 resolution?
As far as I can tell using Adobe when you dig right down to the pixels there is no difference between 1920x1080 and 2304x1296 resolution.
regards
Ah yes 44%. I must have botched my bracketsIf it's just simple math, it would give you 44% more pixels. (2304*1296)/(1920*1080) = 1.44
for a script for 720p 120fps 35MbpsCould anyone help me by create a code for 720p,120fps,35Mbps ('old' firmware 1.2.10)
I found from funnel that list, but I'm not able to convert it.
Improve highlights and get raw WhiteBalanceNobody knows what "#fix ae/awb/adj locks" means?
