Z90 Master V9.0.0.31 firmware update
DDPAI_Official
Shenzhen
China
Z90 Master/ Z60T/ Z60 Pro/ Z50 Pro/ N5 Pro/ N5 Dual
Hello everyone,
The latest update of the Z90 Master firmware, V9.0.0.31, following the V9.0.0.27, is now available.
This update mainly improves battery voltage detection and display accuracy, further enhancing the stability and reliability of parking monitoring related functions. Below explains what’s added or improved.
  • Optimized battery voltage detection logic from off-state detection only to real-time monitoring during both driving and parking.
  • Adjusted battery voltage readings for IPS display to better reflect actual vehicle voltage under various temperatures, vehicle types, and system loads.
Hi! Is this available globally? I checked yesterday and got no update.
Also, any chance of shorter parking monitoring periods in future versions? Lowest I can set is 12h, which is too much for my needs and drains battery unnecessarily.
Hi,
This firmware update is currently only being released for certain regions rather than globally. If you have not received the update notification yet, it means the update has not been pushed to your region at this time.
Regarding parking monitoring, the minimum 12-hour duration is not expected to change in the short term. If you still feel the power consumption is too high, enabling sleep mode should help reduce battery usage during parking monitoring.
