1. Does the dot pattern really protect from the heat?
I suspect it might do the opposite for this camera! The dots are good at absorbing heat from the sun, since there is not much mount between camera and glass, the heat from the dots may actually warm the camera more than clear glass would. Probably depends on the car.
2. Has anyone who HAS NOT modded their camera cooling tested for the overheat with the latest firmware?
I've never seen an overheat in UK weather, if you live in Florida then you should probably expect an overheat in parking mode, as many other cameras would too. Don't know about Michigan weather, but as long as it always records while driving then I don't think it is a big issue. For EGS that was an issue with his test camera with original firmware.
3. I see mention of the H.264 vs H.265 encoding - does one of these use less SOC horsepower than the other? And how does one switch modes?
It will make almost no difference to the "horsepower", uses a little extra for the video compression, but less for writing to the memory card because the bitrate is lower. To switch, stop recording, then press and hold the mute button (think it is the mute?) until a white icon appears on the screen indicating H265. You wont notice much difference in the results, unless your computer can't play the H265 properly.
4. I bought a hardwire kit from Amazon and I realize now that the LVC on it is 11.6V. This seems to be WAY too low. So I haven't tried to install it with the hardwire kit yet, as I want look for one with a higher cutoff value. (I did confirm that the LVC does work right at the 11.6 value by testing with a bench power supply). Does anyone have suggestions on a good kit with a selectable LVC value?
You can use the Viofo HK3, available on Amazon. At some point there will be a proper Zenfox hardwire kit.
Is there a way to get it into parking mode when running this outside the car (plugged into my bench power supply)? I would like to measure the power draw when in parking mode. Since it would not see any GPS satellites in this situation, would it ever go into parking mode?
It will enter parking mode on a simple USB charging cable, if it does not detect any movement on the g-sensor for a few minutes.
We don't know that your hardware is the same as the test versions we got here, yours may be more heat tolerant, be interesting to hear your results, although remember that all cameras have limits! If it is too hot for a human to drive, don't expect the dashcam to be able to cope either!
5. Is low bitrate recording or timelapse recording more power-intensive when in parking mode?
There is not much difference, very low frame rate timelapse has a small advantage on power, but low bitrate is the more useful in what gets recorded.
6. Can the interior camera be effectively disabled? (In the interest of reducing heat?)
Only by getting it hot!
7. Has this overheating problem appeared on unmodified cameras without the rear channel being active?
It will if it gets hot enough, not many people have been experiencing overheating though, the reports are from Texas, and wherever HonestReview lives, Florida?
Sorry for all the questions at once!
Best way to do it, much better than many different posts!
Welcome to the forum
