Your EXE works very well.
I have attached autoexec.ash modified by your EXE for the May 07 2016 firmware from mini0806.com. I can confirm i took a test sample clip and windows reports the bitrate 23.96mbps.
Thanks!
Could you upload the memory dump you are using ? I'll fix it if it's brokenNope... It doesn't work for me. The last one (before firmware upgrade) did... Not the iTracker one, the regular mini 0806 one.
I did use you exe. It produced the code pasted at the bottom of the post. Still bitrate is around 10 Mb/s after using it (1920x1080@45fps). No 24Mb/s for me I guess...
What system are you going to use for your liquid nitrogen cooling?
#Generated by MBP by Pulsarz
writew 0xc057c6c6 0x41c0
writew 0xc057c6c4 0x0000
writew 0xc057c6ca 0x3f80
writew 0xc057c6c8 0x0000
writew 0xc057c6ce 0x3f80
writew 0xc057c6cc 0x0000
writew 0xc057c6f6 0x41c0
writew 0xc057c6f4 0x0000
writew 0xc057c6fa 0x3f80
writew 0xc057c6f8 0x0000
writew 0xc057c6fe 0x3f80
writew 0xc057c6fc 0x0000
writew 0xc057c726 0x41c0
writew 0xc057c724 0x0000
writew 0xc057c72a 0x3f80
writew 0xc057c728 0x0000
writew 0xc057c72e 0x3f80
writew 0xc057c72c 0x0000
writew 0xc057c756 0x41c0
writew 0xc057c754 0x0000
writew 0xc057c75a 0x3f80
writew 0xc057c758 0x0000
writew 0xc057c75e 0x3f80
writew 0xc057c75c 0x0000
writew 0xc057cff6 0x41c0
writew 0xc057cff4 0x0000
writew 0xc057cffa 0x3f80
writew 0xc057cff8 0x0000
writew 0xc057cffe 0x3f80
writew 0xc057cffc 0x0000
writew 0xc057d026 0x41c0
writew 0xc057d024 0x0000
writew 0xc057d02a 0x3f80
writew 0xc057d028 0x0000
writew 0xc057d02e 0x3f80
writew 0xc057d02c 0x0000
writew 0xc057d056 0x41c0
writew 0xc057d054 0x0000
writew 0xc057d05a 0x3f80
writew 0xc057d058 0x0000
writew 0xc057d05e 0x3f80
writew 0xc057d05c 0x0000
Hi Pulsarz, Nigel, everyone,When I Press de "OK" button to stop recording the camera displays the circle dots like is stopping recording and It has freeze.
Same problem with 2 diff. cards, both firmwares, both slots.I'm going to test with:
a) different firmware version (2016-01-04 most likely)
b) different microSD card (although the only other one I have here is a Sandisk, so we'll see)
Thanks Joel, I just went into research mode and discovered that. The key difference is write speed:Evo and Pro are different cards. You want the "Pro +".
I've already ordered one anyways. Just figured I'd post up my findings in case it helps someone elseWith the 0806 I have learnt not to over analyze and get technical. Quite simply and frankly, it works with some cards and not with others. With all due respect, I don't much care what the specs are. I know the Pro+ works. I have an EVO and it doesn't work. That's enough for me to go with the card that everyone here recommends.
what is the firmware version we should upgrade to which reflects the slightly lower bitrate version?
D | Latest Glitch & Honesty About Firmware | Mini 0806 | 1 | |
Latest mini 0806s? | Mini 0806 | 0 | ||
S | Techmoan's latest video | Mini 0806 | 22 |
