For next firmware upgrade, is it possible to show battery voltage on screen on regular recording and/or parking mode so that we may know the correct setting for our parking guard hardwire kit? This would also help in diagnosing cam freezing issue.
Oh yeah. Totally forgot about that!the camera input is 5v, you're not going to be able to read the vehicle battery voltage
I think you can use any OBD readers to monitor battery voltage and health.Oh yeah. Totally forgot about that!
Oh I have one (see video on previous post). I was just thinking of seeing the battery voltage as the dashcam successfully saves the last video if ever the cam do freezes. But I forgot that the parking guard wiring converts the input voltage to 5V before going to the dashcam so it won't see the actual batt voltage.I think you can use any OBD readers to monitor battery voltage and health.
Hi Rayman,LOG:
1, reworked Parking Guard function, now 4 options under ParkingGuard:
AUTO SWITCH LAPSE
ALWAYS TIME LAPSE
MOTION DETECTION
NORMAL RECORDING
2, split the time lapse videos for 4GB file limit
download:
www.mini0906.com/firmware/FIRMWARE_20180124.zip
Hi Rayman,I assume the options are.
1. Auto switch - motion detection changes frame rate from 2 to 30?
2.Always time lapse - disables motion detection.
3. Motion detection- only records when motion is detected
4. Normal recording - records 1080p 30 +1080p 30 continuously?
on the last firmware sometimes does not perform cyclic recording, does not finish some video files, sometimes the GPS does not work...
My speed at the roundabout is 24 km / h!
Auto Switch Lapse - the camera will record low frame 720P 2fps lapse video while parking, but if there is motion detected it will auto switch to 720P 30fps for 15 seconds recording then auto switch back to 720P 2fps after image still
Always Time Lapse - the camera will record low frame 720P 2fps lapse video all the time while parking;
Motion Detection – the camera will auto switch on motion detection function while parking, if there is motion detected it will record video for 15 seconds;
Normal Recording – the camera will continue record normal video even after vehicle parked, it will be a huge storage consume.
While am using the motion detection in parking mode, what i observe is, the camera turns off if motion is not detected for the time period its set for the camera off.
ie if camera off is set for 1 minute or so, while in parking mode, if no motion is sensed for 1 minute, the camera turns off. I guess the expected function is camera shouldnt turn off in parking mode irrespective of the turn off setting.
You mean it should turn off than staying in standby mode?.if motion is not detected for more than 1 minute, when my camera off time setting is for 1 minute?While am using the motion detection in parking mode, what i observe is, the camera turns off if motion is not detected for the time period its set for the camera off.
Seems to be functioning as intended. The camera doesn't turn off, it goes into standby and waits till motion is detected again.
In my case its turning off after 1 minute when motion sensor parking mode is selected.its not staying in standby.
Sent from my SM-G935F using Tapatalk
S | looking firmware for mini 0906 | mini0906 | 19 | |
J | 0906 Firmware Updates | mini0906 | 4 | |
0906 firmware update Nov.21.2017 | mini0906 | 25 | ||
0906 firmware update Nov.01.2017 | mini0906 | 33 | ||
mini 0906 firmware updated 2017.10.13 | mini0906 | 28 |
