dc9mm
YES adapter that came with camera , Its NOT a power issue
Test it first, using default settings as much as possible, then there is minimal chance that you are causing any problems!When I get new camera not sure If I will update firmware maybe just test camera first. Assuming it has older than 2.0 firmware installed .
hardwire kit has an ACC wire to know when the car is on or off, nothing to do with voltagesDoes the Hardwire Module that drops the fusebox from 12.4 volts to 5 volts also send a signal to the camera when it sees the cars voltage drop from 14.6 volts (typical voltage running off alternator) to 12.4 volts (typical car battery voltage is 12.4 volts). Then when the Hardwire Control module sees the 14.6 volts again send signal to camera to take it out of Park Mode?
The time varies since without HK3, the cam depends on a 5 minute continuous period of no motion (visual/vibrations).Just let the car sit long enough to go into Park Mode in my case the time varies from as fast as 10 minute to so far as long as 35 minutes. This is when it stops writing to the SD card. Then once it starts writing to the SDcard you get the 1 minute clip length problem.
The hardwire kit monitors the Acc wire to determine if the key is on or off. With the key off, you can't drive, so you are assumed to have parked, and it goes into Parking Mode (in about 5 secs).Not sure on the Hardwire power kit. Does it some how tell the camera when to go into and out of Park Mode?, if so HOW?
