this over sharpening is an A7 problem at the moment
"At the moment"... Does that mean this is fixable in firmware, and is it likely to get fixed? With a little googling I see others had this issue with the WF1, also.
For a fair test, you not only need to compare the same locations/same distances, but you also need the same sort of ambient lighting -- that's why side-by-side tests are best. (Those, or tests performed along the same route within minutes of each other.)I've been using a DOD300w but I just got the Marcus 3 and moved the 300w to the rear window. I was very excited about the Marcus 3, but now reviewing the video I took today I'm deeply disappointed.
The quality is terrible compared to my 300w; compression artifacts and sharpening halos abound. It's worst in super-HD mode (60fps HD), but hardly any better in regular HD. I made some comparison shots (edit: I used the 30fps HD mode on the Marcus 3 for these comparisons), but because I'd already installed my 300w in the rear window, they're shots from different days (I re-drove a route I already had a 300w video for).
First, 300w on the left, Marcus 3 on the right (not in the same location, but I tried to get a similar car at a similar distance):
Here, 300w on top, Marcus 3 on bottom (both cropped but not scaled):
Here, Marcus 3 on the left, 300w on the right (sorry I'm not consistent!):
Is this normal for Vicovation products? The only dash cam I've ever had is the 300w, and it's performed superbly with the exception of an annoying dead battery. The Marcus 3 has a wider field of view, which is nice, but at this point I'm probably going to return it unless anyone has any better advice.
Regarding the CPL filter, the back of the filter mount is not covered with anything (like a cap, or just pure plastic, it's just a round frame with the filter in front and no cover on the back; the mount diameter exceeds the width of the camera by about 3-4mm on each side), so light enters inside the casing and causes a small reflection of whatever is behind the camera (metal, windows, etc).
http://imgur.com/a/vWcC5#0
Hm my firmware is different.
and my Transcend 64GB card does not work.
service@vicovation.com taken from http://www.vicovation.com/catalogshow.asp?IDno=7&lang=enWho are you contacting (e-mail) for vicovation? I'm trying to keep in touch with them for the latest information.
So far, the image quality at night isn't great, but hopefully the new updates work great.
First, I would like to know what is your power magic configuration voltage setting.Do you guys know if using a power controller is bad for the marcus 3?
I have a blackvue "power magic" power controller hardwired and lately I've noticed my marcus 3 would restart. It's recording then it will play a sound, the red light goes off, the screen comes on, then about 3 - 5 seconds later it begins recording again. Not sure if something is wrong with the device or if the power controller is doing it. I did not have this issue with my old BV cam.
I will plug it into the normal 12v today to see if it does the same thing.
It seems your battery voltage is around somewhere close to the configuration voltage.
Please check out the voltage of your battery.
new firmware for M3 and M1
http://www.vicovation.com/catalog.asp?KeyId=3&lang=CHT
not very impressed
in the archive is two firmware and english manual. I'm very disapointed because is noise in videos. I think the reson is the WDR.
sorry for my english ๐
