I suppose Gitup does not have enough staff for doing all the software things efficiently. So they should rather concentrate on finally publishing the app insted of tinkering around on novelties within the firmware.
I like that idea, it would also let you lock the WB while in the air with no access to the button 🙂"Auto-Lock White Balance"
"WB Lock" requires a side button press and the screen to confirm that it was properly pressed and the WB is locked. When you can not confirm that because of your mounting system you cannot trust on the side button.
In my opinion, the Git2 does a very accurate job regarding to color temp selection when the recording is started. It’s also very quick adjusting WB on the fly, but that leads to a little issue: “Bouncing WB”. When you go from one color temp to another (even for a tiny amount of time) under shady areas like trees, bridges, etc. the coloration changes too frequently giving an unpleasant result. Then, the option to automatically Lock the WB at the color temp present when the recording is started should work for this.
That one is already in the list if you mean "Rotate 180"."Vertical video flip"
I don't know how Gitup is organized with internal purposes. .
I tried this program and i had no issue importing the Git2 files. Every PC is different so i can not guess what caused the issue to you. It could be codecs, the framerate/size of your video files, incompatibility due to another software installed, etc.
All i can report is that GoPro Studio (latest version) worked fine on my PC. The thing i didn't like was the fact that the program does a conversion prior to the edition itselft, making the process a lot longer. So, i'd recommend you Adobe Premiere Pro instead.
I can only confirm this is already implemented in latest firmware, will check other suggestion in detail.That one is already in the list if you mean "Rotate 180".
If you actually mean flip then like mirror, I think it is something for the video editor to do.
It will be in firmware 1.6 which is not released yet, and should not be expected anytime soon.Hi @gitup, i think you mean "will be" implemented instead of "is already", isn't it? Please correct me if i'm wrong.
Vivid, Colourful, Normal, Colourless, Dull, Monochrome, Sepia.Yeah, with "Low Color" i mean being able to reduce color saturation to get a more neutral footage (two levels would be ideal as it was done with positive saturation) So it would look like: Normal/Sepia/B&W
+ Colorful
++ Vivid
- Low
-- Muted (or any name)
The current system works rather well in most circumstances compared to other cameras I've used, I'm not sure that just turning AGC off is what is required for the circumstances in which it does not work so well...I'm adding the audio suggestion to the main list.
OK, we will add some faster shutter speed for photo.I would totally vote for more shutter speed options in photo mode 1/2000, 1/1000, 1/800, 1/500, 1/200, 1/100 as it provides the fast shutter speed for action movements and i also would like to shoot panorama but thats difficult without fixed settings.
There is nothing new added since the beta version, take some time to optimize the Thai language translation, so will official release the firmware soon.And for Git1 when will be ready the stable firmware 1.4? You have forgotten the "first child"...
@omegamoto , thanks for your suggestion, I rechecked it again, am afraid too much options added.
In future firmware, it will support load the options via configuration file from SD card, if we want to add more not often use options, is better to only support by config file.
Also maybe it will support fast switch between different configuration files.
And currently mainly working on "Git3" now, so don't have too much time to add new features on Git2, going to release a new Git2 beta version next week.
