DrekiTech
- Jun 14, 2015
- Vancouver, BC
- Canada
- A129
Curious what your thoughts on these 3 cameras are.
When did Blackvue enter the 3 channel market??? This must be a very new device!
DR770X Box
BlackVue DR770X Box features front, rear and interior protection for your vehicle, powered by Sony image sensors for best image quality under any light. Also included are GPS logger, built-in Wi-Fi, Cloud connectivity and built-in voltage monitoring for Parking Mode.blackvue.com
Big Question!
Does the Blackvue do real time + live recording parking mode or is the only setting Motion Detection?
Blackvue is a buffered parking mode, with motion detect + impact alerts. I believe the cam can also do timelapse with buffered events. If cloud function is enabled it will upload events to the cloud over an LTE connection.
Some thoughts:Curious what your thoughts on these 3 cameras are.
Not sure I agree with that. There is a point where the viewing angle is too wide, at which point you can see the front windows, but the detail in the rear becomes too low, and then you either need 4K resolution, or preferably seperate left and right interior views.Interior Camera
1. Viofo A139 has the best image quality and 2nd best viewing angle.
The Gnet has far too much motion blur, it is using maybe 1/3rd the shutter speed compared to the Viofo. Motion blur is the biggest problem for night video, and I put it last because of that. The Blackvue might not look good, but it is also far less motion blurred.Night Video - Front
1 Viofo A139 clearly wins. Gnet did reasonably well.
Blackvue always uses too low of a bitrate, which is far more obvious if you are not watching on Youtube with further bitrate reductions.The Blackvue fails here and the plates are a soft out of focused smudge.
I think the Gnet has gone too wide for 1080 resolution.
But you don't see the front window at all on the Gnet Interior Camera? Matter of fact, to me it's the perfect viewing angle because you can see out every window precisely the right amount. There's a trade off of course. The Viofo A139 creates a crisper and sharper image with a reduced angle. The Gnet captures the wider angle, and due to the 1080p, the image is softer.
Personally, you aren't relying off the interior camera to be capturing plates. The front or rear are going to be the saving grace, and hopefully if someone sideswipes you, part of the action will be caught on one of these two cameras.
Point of an interior camera is to capture an event that Front and Rear can't see. Even if it isn't in crystal clear definition. I'd rather capture the car sideswiping me that missing part of it due to a lesser viewing angle. Also if the police come up to your window, you want to be able to capture that, too. Without much a worry if the police officer's face isn't the highest definition image.
So I would personally, and based upon my preference, give the Gnet a second place trophy on image and a fist place trophy on viewing angle.
Looking again, I agree that the Gnet has more motion blur. But neither the Blackvue or Gnet did reasonably well here. The Blackvue while less motion blur, has a very soft image lacking definition.
As we're watching on youtube, I'll have to take your assertion at face value. But I am certainly not impressed with the performance of the DR-750X considering it's price point is twice the cost of the A139 3-Channel. Sure, you get cloud support, but the images produced by this camera are definitely lackluster.
Blackvue is at a lower resolution but higher frame rate so I found that there was a bit more detail at speed; that being said the lower res is noticeable, as is the difference in colour processing where blackvue is lower contrast (my thought is to preserve detail in shadows?) but on a winter day like this it makes it look all washed out
Front video BV is 1080p60 while the other 2 cams are 1440p30What comment are you referring in the response above. I.E. (Which Video Taken by the Blackvue).
And what bitrate do you get with that cloud video?Sure, you get cloud support, but the images produced by this camera are definitely lackluster.
If you think the memory card video is lacklustre, you won’t be impressed by the cloud video!
It is 480 resolution @ 0.6 Mb/s… 0.3MPAre you saying the video is further compressed when an event is uploaded to the cloud? If so ugh, I would hope not!
Having you tested and verified the compression is worse when uploaded to the cloud on a Blackvue or any other model?
Well that is the specification on their website!
The USA introduced the 480i (NTSC TV) resolution back in 1954!Dear lord, that's DVD resolution. Welcome to 2006!
The UK exceeded it with 576i (PAL TV) in 1967.
480p and 480i are the same resolution, only difference is that with "p" the lines of a frame are transmitted in sequence while with "i" all the odd numbered lines are transmitted before all the even numbered lines.Well is the resolution 480p or 480i when uploaded to the cloud? Either way, that's pretty bad for 2021!
