HonestReview
- Feb 9, 2019
- Sweden
1. I'm not sure the video signal broadcast over WiFi is 1080p, it seems more like 720 on systems over tried, but I could be wrong.
2. I doubt the resolution / compression compromise of video over WiFi would record sufficient detail for evidence.
I'd rather have a microSD slot in the remote camera and record locally. Oh wait, I already have a Mobius that can do that. No need to connect it all to a single main unit.
The mobius though is still hardwired and requires a power cord. A pitfall for vehicles that don't have a fixed rear window. Trying to run a cord on a vehicle where the rear doors open does not permit a "clean install". You are left with cords that could get jammed in between the door when a door is opened and closed. You are also left with exposed wires that could be pulled on or caught on objects.
Per my above, even if 720p, you don't need Crisp detail. Enough to capture the event. Front and Rear Cameras with far better quality can discern the rest in better detail. As any person or vehicle causing side damage to car is likely to cross the proximity of other cameras.
FYI: Here's a picture of a Volvo Door: You can observe the dilemma in trying to run a cord to the small window without the need to drill through the door's firewall and run cords. Trying to run a cable from the b-pillar to the door externally would risk this cable dangling and getting slammed into the door when the door opens and shuts.
