70mai A500S
lisabon_Q3
Chelyabinsk city
Russian Federation
70mai M300/M500/A500s/A800s/
Interestingly, if I manually press the center button in the car, it turns on immediately. So the electricity is inside, but it doesn’t turn on automatically. Maybe the voltage is too low to turn on automatically? I do not know.
I think the problem may be in the electrics of your car. It is possible that there is not enough current when the ignition is turned on. Try to test it in another car.
Greg295
Slovenia
70mai A500s-front, 1S-rear
I agree. I'm just working on it. I didn’t want to answer because I’d like to wait and make sure to see if that’s it. I think I found a problem.
I had the camera connected directly via the original cable to the usb socket. Now I connected this cable via the included original car cigarette lighter socket adapter.
I think that was the problem. I'll let you know in a couple of days how it works.
Thanks.
SawMaster
SC
Numerous and ever-changing
Car USB ports are notorious for causing dashcam issues. Hoping you will now find the problem solved.
Greg295
Slovenia
To announce that the problem is solved. The problem was only in the adapter.
So!
Always connect via the original car cigarette plug and the original cable.
Talk to you soon.;)
