Several months ago, I had a second BAB-95 battery pack that failed. I shipped the first and second BAB-95 battery packs back to Thinkware and I was told that both of them had a uncommon failure of a chip on the circuit board. I was sent a third BAB-95 and it has been working okay until the past couple of weeks. The third BAB-95 did not completely fail. The battery pack's charge level mysteriously would quickly drain off without any dash camera drawing any power from it. The most recent occurrence of this problem happened yesterday.
I parked my car after my multi-hour drive on Friday 12-Jan-2024. I powered down the Thinkware U3000 2-channel dash camera using the power button on the front dash camera and I then turned off the BATT+/ACC+ power to the U3000 from the BAB-95 using a DPST toggle switch. The car remained parked and the U3000 remained powered down since the afternoon of the 12th.
Monday 15-Jan-2024 at 4:13 PM, I checked the charge level using the iOS iVolt app. It was at 90% | Input 12.6V/0mA | Output 12.8V/0mA.
Tuesday 16-Jan-2024 at 09:56 AM, I checked the charge level using the iOS iVolt app. It was at 88% | Input 12.5V/0mA Input | Output
11.4V/0mA. The output voltage level is very odd/low for the charge level of 88%. I ran some errands in a nearby town by driving my other vehicle. The car with the U3000/BAB-95 remained parked at home.
When I attempted to check the BAB-95 charge level around 3:00 PM, the iOS iVolt app could not find a battery pack to connect to at that time.
Tuesday 16-Jan-2024 between 09:56 AM and 3:00 PM, the iVolt Xtra BAB-95 fully discharged itself. The car was parked the entire time and the U3000 remained fully powered off the entire time.
I checked the vehicle’s battery voltage level to make sure the vehicle itself was not in a low voltage state. I did this since the BAB-95 is connected to constant battery power via its hardwired input charging cable. My battery tester showed the vehicle’s battery voltage level was 12.33 volts and that was after opening the side door and the trunk which awakened the vehicle’s body control module which caused the voltage to drop a small amount. So, the vehicle’s battery voltage level was good!
I tried moving the BAB-95's mode/slide switch from “High” to “Off” and then back to “High” or “Low” and there was no response from the BAB-95. I have a test charging and green (ACC IN) wire harness in my office for testing/charging the BAB-95. I connected the BAB-95 to a DC power supply. When I turned on the DC supply’s output power, the BAB-95 remained “off” as it should since the green “ACC IN” wire had no power yet. I then turned on the power to the green “ACC IN” wire and the BAB-95 started charging. I was able to connect with the BAB-95 using the iVolt app. The app reported a charge level of 1 (one) percent.
The next strange thing was that when I turned off the “ACC IN” power the BAB-95 did NOT stop charging. It was continuing to draw 6.6 to 7 amps. I exited the iVolt app and terminated it on my iPhone and the Bluetooth connection LED turned off, but the BAB-95 was continuing to charge. I even removed the green “ACC IN” wire from the “Output” port and the BAB-95 continued to charge. At that point I turned off the power provided by the DC power supply.
I've been tracking this issue for the past couple of weeks. I've reported my findings to Thinkware. I had to swap out the Thinkware iVolt Xtra BAB-95 battery pack since it's not working correctly.
The Thinkware iVolt Mini BAB-50, BlackboxMyCar PowerCell 8, Cellink B and BlackVue B-112 battery packs have been working well in that same vehicle.
