- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
64gb will work but you need to format in the camera before use
I've had 2 A118-C's (from @spytec) in my wife's car (front and rear) all summer with temperatures up to almost 100F. She has assigned parking at work and her car faces north/south so one or the other cameras is in the sun all day.
I check the cards about once a week to make sure things are working as they should (the G1W-H camera in her car would fail on hot days) and there have not been any recording issues, corrupt files, or out of focus videos. With luck this will continue.
yes, but you can open the case of the gps unit and flip over the circuit board, then mount it on the windshield. you should keep it at least a foot away from the camera though, to avoid interference.Just ordered this. It's $53.79! About what I paid for my G1W, but I want to replace it with a capacitor camera.
The optional GPS unit goes on the dash, not the window, correct?
I have 64gb memory card from pny. And also with Sandisk both do the same thing. Tried one another card as well. All same..
No. Files are stored in linear fashion in a "MOVIE" folder.What file format does the A118C use to write to the memory card? I.e. Does it use DCIM?
I have bought the b40 from gear best. Fast shipping. Thanks
But I have the problem. Recording are corrupted. Some good but most bad.... How to fix it? Is it bad camera
Any warranty on those if unit is bad?
Thanks a lotit needs to be formatted FAT32 but should work, camera can't format it but provided you use appropriate software it should be ok
