The default settings is not same.I am curious if there are any new firmware releases coming soon?
Not that i have noticed any bugs with mine (STI_A119_170221_V2.02) (the STI part is SPYTEC - They apend the SPYTEC Splash Screen On start up and default to MPH instead of KPH)
I Don't remember if I was on 2.0 or 2.01 when I received my cam, but first incorrectly loaded the VIOFO 2.02 firmware and not the SpyTec. It still worked there were just differences I just noted.)
Hi, recently got 3 units of the A119 (with GPS module) together with Lexar 300X 64GB memory cards. All 3 units displayed "memory error" with the Lexar cards after a few days of recording. Swapped the cards between the units and still had the same error. The cards were formatted within the A119. Firmware is 2017.2.21 V2.02 (out of the box).
I thought the Lexar 300x cards were suitable for A119. Any solutions? An older firmware perhaps? Thanks in advance!
I suspect that your cards are either not formatted properly or there's an issue with the batch of cards you got.
try to reload the latest firmware on one of the cameras.An older firmware perhaps?
I would reload the firmware.Is my unit bricked now?
It flashes when recording, solid when paused
Same here showing the same as Diggie apart from mines working and recording fine it's just the rec led static when recording and rec led flashing when paused. Latest firmwareMine is doing the opposite, when it is recording:
When it is not recording:
- The red on-screen indicator flashes
- The rec LED button is solid
This is fine, except that it got into a state where it was a) not recording and b) rec LED was solid, so I thought it was recording but it was not.
- No on-screen indicator
- Rec led light is blinking as a warning
Which LED are you referring to? The LCD red dot will blink when recording normally and disappear when recording is stopped. The red light on the REC button will remain on when recording normally and flash when recording has been stopped. Though the REC button light will go steady on again when you enter the menu.Same here showing the same as Diggie apart from mines working and recording fine it's just the rec led static when recording and rec led flashing when paused. Latest firmware
Sent from my SM-G900F using Tapatalk
