Frenky Tan
- Jan 19, 2017
- Malaysia
- Viofo A129 Duo, 119 Pro, 119S, Yi DashCam
They bring up Gitup as their new action camera line up product?
Gitup is under Viofo. If you check the address on both websites is actually the same place.
As you can see in the invitation picture, the camera form factor is the same as A119. So I expect as hardware only a CMOS change even could be very interesting to offer also Wi-Fi, but as I already wrote, this means PCB change. But also adding some accessories, because from the GitUp cameras, the PRO version means more accessories. If this is true, maybe is better to make your request, maybe they will add into the standard package.
My vote is for:
- suction cup
- angled Mini USB adapters
- Micro SD Micro USB OTG card reader
enjoy,
Mtz
For the love of g@d, NO MICO USB!!!!!
and this is a problem?
I've had 2 camera's with Micro USB, and both just broke off.... I'ts just that micro USB takes more presure to enter the plug, the mini 5 pole usb is much easier to plug in, and never came off from any board I had.
Just saying.
PS didn't we have a discussion like this before in another thread?![]()
dual channel rear cams are usually trash tho..
would be better buying a viofo a118 for rear cam
not to mention the strain it might put on your sd card, will prob fail quicker no matter if it is mlc or not lol.
He said "Micro SD Micro USB OTG card reader" not Micro USB cable.
I'm guessing you misunderstood what he was asking for, he was talking about a USB/Micro USB OTG card reader, you can use them to view files on your PC using USB and view files on an Android phone/tablet using Micro USB, he wasn't suggesting the camera should have Micro USB connectors
Thank you both!
I consider the USB adapter to not be so important like the Micro USB adapter because people have their smartphones in the car, not the PC, desktops. That adapter should stay always in the car and not take it at home, because at home almost everybody have some USB adapter or Micro SD card reader to be used with the PC or laptop.
enjoy,
Mtz
Adding also 5GHz is the only way to go for a dashcam company which want to be a leader in this market so I expect Viofo to do this in future products, but not in A119 Pro. 5GHz is perfect for dashcam usage because there are no objects (walls) between camera and smartphone.use 5GHz chip Wi-Fi rather then 2.4GHz
