- Nov 5, 2016
- Carson City, Nevada (USA)
- VIOFO, GitUp, INNOVV, QVIA, GUARD TRAK + More on Amazon.com
I will try to get some spare pieces and make them available.
The Next batch of V2 should contain EVA foam pads then.
But that's only with the mount not with the GPS-base?It works, I applied one of the spare EVA pads from the SG9665GC to the A119S's V1 mount, took care of the vibrations from the subwoofer. 3+ months later it's still snug.
Good grief. Does Viofo (or whoever the manufacturer is) have a QA department before they keep releasing products?
I'd never heard of "EVA foam" outside of this discussion before. Apparently, it's also known as "craft foam".
http://www.hobbylobby.com/Crafts-Ho...t-Foam/Black-2mm-Thick-EVA-Foam-Sheet/p/28626
same stuff only the one we use is 0.5mm thick and is 3M adhesive backed
May work on V1 alsoBut only for V2?
I don't see why it wouldn't work on V1 but we will find out.
I would think that maybe the foam will push the pins further apart for V1. V1 contact strip are a bit deeper than V2's. Might cause more disconnects if anything.
I would think that when latched onto the mount, the camera contacts should be similar in distance to the pins. This would simply eliminate any "play" once he foam has been compressed. If the "play/movement " of the camera on the mount is main reason for any momentary pin disconnect, then this should help quite a bit. We shall see I guess.I would think that maybe the foam will push the pins further apart for V1. V1 contact strip are a bit deeper than V2's. Might cause more disconnects if anything.
Will this foam come already attached, or will it be up to the customer to attach only if they feel they need it?I just met with the VIOFO guys in Shenzhen. Here is a photo of the new custom die cut 0.5mm EVA foam pads. It will be stuck to the camera side not the mount side.
I'll be bringing some home and will send to OCD Tronic customers as needed. If I have enough left I'll offer it as an accessory for non OCD Tronic customers as well.
