I switched to 2.5 because of all of the issues with 2.9 and 2.10.Hi all, been lurking for a while and signed up recently, I've got an A129 Pro Duo, had it for almost a year now.
I was running the v2.9 20221225 fw, but thought I'd try 2.10T., but I've noticed something, and apologies if this is already know I did have a quick search, which didn't answer my question..
Parking Mode on v2.10T.
If you select AED on the camera then go into the app it says its low bitrate.
Change it to AED in the app and the camera says low bitrate.
This is not an issue on v2.9 20221225.
Just me or a known issue?
Thanks.
This is common for T (Testing) firmware.Hi all, been lurking for a while and signed up recently, I've got an A129 Pro Duo, had it for almost a year now.
Thanks.
Hi all, I've got the 129pro front only cam with V2.2 . I've been reading this thread carefully and it appears that my next upgrade should be v2.5 !
Does anyone have a direct link for this version as I understand it's the best option to improve the wdr video quality ?
Thanks all in advance
Above v.2.5.FWA129P_+V2.5+Build20210806.zip
drive.google.com
Below are other versions just in case.
Viofo A129 Pro Firmware
Firmware updates for Viofo A129 PRO dash camera. This includes the A129 Pro DUO. Caution! Incorrectly installing firmware can cause your camera to become inoperable. Sometimes permanently. Firmware listed on this site comes directly from the manufacturer. Install at your own risk and only...www.captureyouraction.com
This is a private site and the owner has the right to post on it what he sees fit. Viofo cannot tell him which firmware to install and which not.Thanks for the links.
Have you noticed that on the website you linked to https://www.captureyouraction.com/pages/viofo-a129-pro-firmware they don't list fw 2.5? It goes from 2.4 straight to 2.7. Any idea why?
This would usually lead me to think that something is wrong with fw 2.5 and that VIOFO advised against installing it but I can see just above a few people recommending fw 2.5?
Any explanation why this website is not listing fw 2.5?
I've got my old A129pro running fw 2.1 and recently it started to add all parking mode footages into the "RO" folder.
I bought a 2nd A129 pro last year and it came installed with FW 2.7, and so far it's been running without issue.
I want to update my old A129pro, the one that locks all the parking mode videos, was thinking to go with 2.7 since it's working fine on my 2nd A129 pro
But a quick read of this thread and I see most people recommending fw 2.5.
Maybe I can try 2.5 and see if it works fine, if not try 2.7.
Though I'm just curious about why fw 2.5 is not available from the above website, I see you also provided a link to download fw 2.5 via a google drive
V2.5 may have been a beta and never officially released by Viofo, I don’t recall. Either way, I don’t have this version in my archive, so it never ended up on the site.Thanks for the links.
Which firmware version do you recommend running?V2.5 may have been a beta and never officially released by Viofo, I don’t recall. Either way, I don’t have this version in my archive, so it never ended up on the site.
I would try the latest, V2.9, and see how you like it. It's easy enough to change versions to see which you like best.Which firmware version do you recommend running?
The firmware can be upgraded and downgraded without harm to the DVR.Last question, in general with electronic devices, it's not recommended and sometimes impossible to downgrade. What about dashcam and the A129pro in particular? Can we safely downgrade fw? (followed by a factory reset after updating fw)
Yes, you can change firmware to any version without issue.Hey, thanks for the insights.
Ok, I'm gonna try 2.7 then since it's working great on my other A129 Pro.
Useful info. I've often wondered but never got round to asking...Yes, you can change firmware to any version without issue.
Why should it be dangerous?So is V2.9 firmware safe to download?
