Here: https://dashcamtalk.com/forum/attachments/viofo_a229_pro_bitrates_20230925-png.67791/Does anyone know if the bitrates are listed somewhere? I mean what is the bitrate for 2 channel in max resolution, 3 channel, etc. Thanks.
Thanks, just trying to make sure the 256 GB Sandisk Max Endurance I already has can handle the highest bitrate for 2 channel (80ish MB/s).
I'd imagine it would be good with most name brand cards otherwise they'd have to stipulate in their promo material, the limitationsThanks, just trying to make sure the 256 GB Sandisk Max Endurance I already has can handle the highest bitrate for 2 channel (80ish MB/s).
Supposedly the Samdisk max endurance card only does 40 MB/s sequential write? https://www.westerndigital.com/tool...sd/data-sheet-max-endurance-uhs-i-microsd.pdfI'd imagine it would be good with most name brand cards otherwise they'd have to stipulate in their promo material, the limitations
I just assumed the linked chart maker confused Mbps with MBps.I think you are confusing Megabits per second with Megabytes. There are 8 bits to a byte, so 80mbps is only 10MB/s.
So the issue is not write speed, it is endurance of constant writing to the card.
Someone correct me if I'm wrong...
You are correct with the 10MB/s, so an ancient Class 10 card will work fine, and a Class 6 is quite likely to work, but modern cards have issues when writing multiple channels, they need time to clear the deleted areas ready for reuse, and to perform their wear levelling, and then they slow down when they get too warm; so modern cards, unlike the old Class X cards, do not guarantee any write speed unless the camera provides a lot of buffering, which dashcams don't like to do, just in case of data loss on power failures.I think you are confusing Megabits per second with Megabytes. There are 8 bits to a byte, so 80mbps is only 10MB/s.
Neither the manufacturer nor the users who received these models know the answer?In the description on the manufacturer’s website, the A229 Pro and A229 Plus have the same characteristics for the rear and interior cameras.
Does this mean they are interchangeable? Can the rear and interior cameras from the A229 Pro be used with the A229 Plus?![]()
It has been reliably working in the Viofo Dashcams I have.Is the Viofo SD Card good?
