lufa6977
- Jul 22, 2024
- Virginia, Shenandoah Valley
- United States
- Vueroid S1-4K, Viofo A129 Pro Duo, A229 Pro, IR, Telephoto
On the A329, you can use a USB-C Stick instead, with an extension cable if you want, then the hot controller chip is in the stick, not the camera, and the USB-C connector will stay in no problem!
Edit: Not sure what that does to power consumption, I've seen power figures with external SSD, but not with USB sticks...
Wish I could use a USB-C stick, but I have the A229 Pro, I have to use an extender of some sort. The extenders I have are just slightly thinner than a microSDXC card and will not stay seated. I have considered an extender with a cable, but not sure which ones will stay seated in the housing. I started playing with this earlier this year, but gave up. I am waiting to see what VIOFO offers next along the lines of the A339, Pro or otherwise. If I can get a 3 channel that has front, IR and telephoto I would seriously consider getting the camera. I would then move the A229 Pro to the rear window and remove the A129 Pro Duo that is presently on the rear window.
