2000rpm
- Apr 5, 2015
- United Kingdom
- Many, including JooVuu, Mobius, Street Guardian.
Problem is I wont be able to remove the camera from its mount unless I remove the adhesive mount with it.
Not that I plan on removing unless it breaks etc.
Can you get to the sd card if you want to take it out or if it needs replacing?
The bite out of the middle right of the view is not ideal. I'm wondering whether you might just be best to mount high up on the driver's side and accept that you're in a no-win situation.
A big problem with a permanent mount is that if the MoT tester doesn't like its location and can't easily remove it they might fail your car until you remove it. But your car is new so I expect your cam will be dead before your first MoT.
Here's what my Mivue 538 sees from roughly the same location as your cam, and the second picture shows where it's mounted (the Mivue lens is at the bottom of the cam, and the mount it is fitted to is not wha:
![](/forum/proxy.php?image=http%3A%2F%2Fi459.photobucket.com%2Falbums%2Fqq315%2Ffluffybuck%2F000000000000%2520c%2520mirror%2520blocking%2520view_zpso0dbiucq.png&hash=4b6514b8073792d48c960981bbc5ab17)
![](/forum/proxy.php?image=http%3A%2F%2Fi459.photobucket.com%2Falbums%2Fqq315%2Ffluffybuck%2FPICT0174_zpsrjfsyoq9.jpg&hash=cfb3c17bdce91179f59ddca6b2a64cda)
