If the only issue is a slight buzzing noise that a) doesn't affect you while you are driving, and b) doesn't affect it's primary purpose of recording an incident, then I'd say you're almost ready to set-and-forget and stop worrying about it. For example, I have some black dots in the upper corner of one of my camera's view, but I'm not going to reposition it as I don't think it significantly detracts from the recorded video.@Sutton - I'm already becoming fond of it like a poorly baby. Should I give up on the poor little soul and send it back? Or should I nurture it and help it overcome its problems as it struggles through its life. A life that's just begun...
Then the setting is wrong. The UK's mains frequency is 50Hz.I'm on 60hz.
If I was David I'd stop listening to Sutton's morbid insistence that the camera is a lemon and should be replaced.(...) stop worrying about it.
But Dave, with all your A119 problems I feel like returning mine lol. Also u mentioned ur set on 60 HZ but if ur located in Europe should u not be on 50 HZ North America is 60 HZOK, so flickering has gone in the daylight. That's fine, it's the indoor lighting "clash" which caused it. I'm on 60hz.
(Also noticed I have WDR switched off, so that's on now).
And I think it may have been me not knowing how to mount/unmount the microSD that's caused the other issue of files - I was leaving the SD adapter in the Mac and just removing the micro SD from it. But doing that, the Mac doesn't register it going in or out. However, that wouldn't explain why it didn't format and remove the previous day's clips when I went through the format process in the cam? The hard reset of the cam yesterday, followed by a card format solved that, and it's working as normal today, removing the previous data when formatted in the cam. All is good, bar the buzzybuttons...
Why would Dave keep that A119 if he has had one problem after another. Would not a true chat friend tell him to send it back while it's within the 30 days to return. A cam with defects are common with low end prices...... I advised Dave the same as I would my brother. Send that sucker back while u can. If u want a dash cam that is similar stealthy shape Dave should think about the Street Guardian which is trouble free.If I was David I'd stop listening to Sutton's morbid insistence that the camera is a lemon and should be replaced.
It figures who would send u a "like"If I was David I'd stop listening to Sutton's morbid insistence that the camera is a lemon and should be replaced.
It should reduce the flickering when recording under indoor lights and possibly street lights that flicker at mains frequency. I've never noticed much difference when used as a dashcam except in some car parks that use fluorescent lighting. It affects the recording, not the playback.What benefit switching to 50hz? Not with you?
Is it for playback, recording under street lights... what?
Whats new with the new firmware you updated at?
YESSSSSSSSSS Don't get me wrong I own an A119 and I love it, it works problem free. I did have one before with a problem and I returned it and bought it again. The new one works flawlessly perfect. Look it can happen with assembly produced items. Its just that the odd time with any product one may not be up to par.Hmmm... I'd just assumed that, as with TVs, the higher Hz the better. But that's playback as you say.
Not recorded under any street lighting as yet so I'll leave it at 60 and see what it looks like when I have.
In reality, I've only really had the buzzybutton issue. The others are perhaps just down to my own ignorance of microSD cards, and refresh rates.
I'll keep going for a few more days, get some night footage to check that's OK, then if I'm still not happy I can send it back.
Those Hz have nothing to do with these 50/60Hz. The 100Hz, 200Hz, 400Hz you see advertised on TVs is the screen's refreshing rate and has nothing to do with the mains frequency.Hmmm... I'd just assumed that, as with TVs, the higher Hz the better.
GO on this site it will explain all... http://urbanvideo.ca/avoid-video-flicker
well, i was one of the testers, and it got tested in my sport truck - toyota tacoma x-runner, which from the factory has lowered suspension, much harder springs/shocks, thicker anti-sway bars, and 18x8 wheels with 255/45/18 tires. my wife hated riding in it because it was so stiff and loud - almost no noise insulation, and wide tires pick up a lot more road noise. i didn't have any buzzing issues with mine.Just to recap for Viofo - test also on off-road modified cars and on sport cars!!!!!!!
I will use a black ducktape over the buttons and test also if the sound goes away. thank you DavidUK!!!
Thank you Thank you for backing me up. One poster said I was morbid insisting David to return it.I think it's unrealistic to expect a dashcam manufacturer to have each of their products, with various options (eg GPS mount / no gps), tested in even 10 or more different cars.
You could line up 10 A119s in David's car and not get vibration issues in any of them. On another day maybe 2 have issues.
As @Sutton said, production line items sometimes have slight variations, especially if there's a person involved along the way. Missing a single dab of glue could make a difference.
