Ambarella A7 Super Full HD Dash Cam 2560*1080, 2304*1296
Hello Doreen,
are LDWS, FCWS, FCMD, LLW functions available for G90 with A7LA30 chipset?
hello pinfi, tks for your kind attention!
the new excellent functions are available on A7AL50 and A7LA70 chipset only. :)
HDR: High-Dynamic Range
F1.8 big aperture supports higher quality of video and supports low-light.
The IQ is still being improved, the most excellent video quality is to be continued. For whom have got samples, I'll provide updated firmware once have.
hello pinfi, yup, the videos on YouKu were uploaded by DOME (BlackView is DOME's brand).
LDWS, FCWS, FCMD, LLW are the functions on A7LA50 and A7LA70 only.
sample you supplied is 30fps, looks ok but a 60fps sample would be nicer, perhaps something longer than 10 seconds would be good also
General
Complete name : C:\Users\oem-user\Desktop\G90 A7LA70 Super FHD 60fps\G90 A7LA70 Super FHD 60fps\G90 A7LA70 (1080p 60fps).mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 26.0 MiB
Duration : 10s 444ms
Overall bit rate mode : Variable
Overall bit rate : 20.9 Mbps
Encoded date : UTC 2014-07-07 08:14:18
Tagged date : UTC 2014-07-07 08:14:18
Writing application : Lavf52.93.0
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Bit rate : 20.9 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.336
Stream size : 26.0 MiB (100%)
Writing library : Lavc52.108.0
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 10s 411ms
Bit rate mode : Variable
Bit rate : 3 388 bps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Stream size : 4.31 KiB (0%)
Language : English
Hello every body :) as promised, I hereby upload the video of G90 A7LA70 Super Full HD 1920*1080p/60fps
https://www.sendspace.com/file/9xcurc
Kindly remind:
If the video does not run smoothly, it's beacuse the frame rate is so high -- 1080p/60fps.
Pls turn of other programs of your computer when playing the video, or do not use an very very old computer,
or change another player to review the video.
LLW: Low Light Warning
When the sensor detects it is dark in front of the car, (G90) device will give driver a warning -- turn on the dipped headlight.
This function is also useful when car enters the tunnel.
LLW is already implemented in many cars to turn on headlights automatically when LL detected.
In dashcams it is another useless feature ( marketing trick ) which distructs driver ). In many cases you dont hear those "extra warnings" ( FCWD, LDWS, LLE etc ) due to them being not loud enough ( too small speaker ), example when you listen radio even 1/2 loud. And warning messages can not be seen on LCD due to dashcam mounted behind rearview mirror.
I see those "extrass" useless and in many cases distructive and danger to safe driving.
Better is to concentrate all efforts on main purpose of dashcam: video quality, stability and performance / functionality. Remove all useless "bling-bling, dong-dong" extrass and add supercaps, wifi, 24/7 parking mode etc.
tks jokiin.
better and improved video will be provied soon.
do yourself a favor and provide at least a one minute segment, if you only put 10 seconds of video up people will just assume that you edited out the worst bit, file size is not an issue
Dear All, I am going to upload new G90 Ambarella A7LA70 vdieo within 1-2 days, pls kindly wait. :)
Dear All, I am going to upload new Ambarella A7LA70 vdieo within 1-2 days, pls kindly wait. :)
is the Ambarella A7La70 version available in your website or in aliexpress ??
