wwwdash
Hi All,
My issue is that when I had my dashcam powered up using the cigarette lighter power, everything worked perfect in Parking mode. Meaning, when I turned off the car and shut the door I would come back and get in and I would never hear "an impact was detected" unless there truly was an impact. (note that my cigarette lighter power has power on at all times). Fast forward to me buying a hard wire kit so I could ditch the cigarette lighter, problem is now, when I turn off the ignition, and before I can even exit the vehicle, the act of me closing the door triggers an "impact was detected".
My question is how would my cigarette lighter power, be different than me hard wiring the dashcam. My girl also has the exact same issue. Blackvue told me me this was a known issue, and they "MIGHT" release a firmware to address the issue (they did address this issue with the DR750 model and up)
My (annoying) work around is to wait until everybody has exited the vehicle and then turn the engine off and exit quickly. If i do this before parking mode is activated I can avoid a false positive. Same for when I return to the vehicle, I will open the door and turn the key to the "on" position to listen for impacts detected, BEFORE opening the trunk to put in groceries etc.
Has anybody had this issue with the hardwire kit vs just plugging in the cigarette lighter for power, I'm having trouble understanding how these 2 power sources could be different.
I know that the hardwire kit has a wire for BATT+ and ACC+, whereas using the cigarette lighter only has BATT+ (but it worked perfectly) unless of course it wasn't going into parking mode while using the Cigarette lighter power, and thus I never had this issue?
Any thoughts from any of you with a similar issue. I'll be honest, I highly doubt Blackvue cares to address this issue, even though they know about it, from my emails with them.
Thanks!
Thanks!
