Updated 'steps' for firmware version 1.9 that I followed to set up the Viofo A129 Duo (non-IR), Thanks for the update Viofo!
The following is very detailed, yet that hopefully makes it easy to follow and understand what's going on.
Flashing to v1.9 on the PC:
- flashed it to v1.9 following the instructions by Viofo (
https://support.viofo.com/support/solutions/articles/19000087812-viofo-a129-duo-dash-cam-firmware).
- After flashing it, the camera restarts. After startup: choose "safely remove" for the USB storage.
- I connected the camera to a travel adapter to power it, so it's no longer seen as an USB storage device.
- After startup, pushed a small pin in the pinhole to hold the reset button for about ten seconds. When you let go the camera restarts.
- After startup: stopped it from recording (if you used the travel adapter) and set the camera to default values using the menu.
- Finally: formatted the SD card (128GB Samsung Evo).
Prepare to use the app to change settings:
- On the camera: hold down the rightmost button until WiFi turns on.
- Connect to the cameras WiFi through the phone WiFi menu, default password is 12345678.
- Start the Viofo app and connect to the camera (updated app: v1.8.3. for iOS).
Use the app to change these settings:
- Loop recording: 10 min (choose whatever you like).
- WDR: On (personal preference, I see more detail in the video with WDR on)
- Parking mode: auto event detection
- Time zone: GMT+1 (Pick your own timezone)
- Live video source: "Both front (rear overlaid)"
- GPS: On
- Camera model stamp: Off
- Screen Save: 15 sec
- Format SD card: YES
- WiFi Password: (choose your own)
Now you lose the connection to the camera because you changed the WiFi password.
So: on your phone, look up the Viofo WiFi, connect to it, enter the new password. Now you can open the Viofo app again.
Then placed the camera back in the car, will see tomorrow what it did during the night.
Hardware setup in the car:
- Camera hardwired with the Viofo HK3 set (switch set to 12V).
- USB cable goes directly to the camera, NOT to the GPS mount.
Minor problem:
One minor problem I ran in to twice in a row: after powering on the camera, the first time I open the Viofo iPhone app and tap "Connect your camera", it immediately says: "Connection lost".
BUT: when I immediately tap "Connect your camera" again, it connects right away.
