CaptnEric
- Mar 8, 2018
- Melbourne
- Australia
- VIOFO A129 DUO, Thinkware F770 1CH & 2CH
Thanks @jokiin and @epsebypoo for the firmware links
I just hooked up my A129. Can you set the parking mode to record upon impact only? Or is it impact and motion?
Sometimes I park on a busy road so I don't need the motion activation but would still like for it to record upon impact
You can try to lower the motion sensitivity down to minimum. Regarding the impact detection, I suggest you test it before trusting it. For many users, inclusing myself, this doesn't work at all in parking mode.I just hooked up my A129. Can you set the parking mode to record upon impact only? Or is it impact and motion?
To enable buffered parking mode you need to select Auto event detection. Unfortunately, there is no "Impact only" option.I updated my firmware but I don't see an impact only option in parking mode
Those are the best settings for what you are trying to achieve, but it will still record some motion even on the lowest sensitivity level. I don't think there is a g-sensor only parking mode option.My settings are as follows:
Parking Mode: Auto Event detection
Parking H-Sensor: High sensitivity
Parking motion detection: low
Time lapse recording: off
Motion detection: off
G-sensor: low sensitivity
When I checked my camera it seemed to record motion. Do I need to change any settings?
Thank you. Hopefully the new firmware update changes this!Those are the best settings for what you are trying to achieve, but it will still record some motion even on the lowest sensitivity level. I don't think there is a g-sensor only parking mode option.
Hey, I'm thinking out of the box for you...put a sock over the camera and you won't get any motion detected... (of course both cams!)
That option is coming soon once Parking Mode G-sensor sensitivity can detect door closing, which is always test #1. Currently A129 perfectly detects door closing only while driving.To enable buffered parking mode you need to select Auto event detection. Unfortunately, there is no "Impact only" option.
When parked in the driveway with parking mode on, it will record 45 second clips every minute or two with mostly just a couple leaves moving in the distance or a change in brightness due to a cloud moving overhead.
It seems an awful long time since we had any updates or any suggestions or here'd from Viofo on this subject. I'm ever hope full there is something big just round the corner!
I do hope so I think it would make a lot of people happy
Don't you!
Or are we looking for something that's unachievable !!
It would make good camera very good!
