Hey, I have problem. I can't connect camera using your last script - "Cannoct connect to the adresses specified". When I connect laptop to Xiaomi hotspot - it's allright. Maybe it's wrong IP adresses? I've tried looking for it, but there is no such things in my router options. Maybe it depends on type.
Depends on a router, thats why i allowed you to set static IP - just look at the end of sta.sh script - comment udhcpc line, uncomment ifconfig, modify the ip address for your needs (must be in the subnet of your network) and then the camera will always have that IP no matter what. (unless, ofc, you use alerady used one)
Ok, I feel like a retard right now but I can not get this to work. Please give me a hint of what I'm doing wrong.
I have enabled "Enable Wifi when camera is turned on".
When I start the camera the front led flashes a couple of times with the normal starup sound.
The camera produces a very short beep sound.
After a while the camera produces a longer beep sound. Approximately 1 second long.
The camera does not show up in my router settings.
Should the name of the network and the password of the network be within " " symbols or not?
Does the router channel matter? My router is set to channel 13.
Cheers Andy_S im no computer wiz but i managed to get C&C and wifi working with a minimum of fuss. How ever is there a way to switch back so i am still able to connect to the yi wifi through my phone?? or is it as stated just remove the files?
Lastly as i have no idea about coding etc when you refer to creating the static IP is this the line that needs to be edited?? . . .
This cannot work, you cannot mount ubifs for write this way.
Well, you can, but it is not kept after reboot anyway, it acts sortof like "tmpfs" with preloaded content on init.
There IS a rw partition - /pref but since your only option to launch anything on boot is by autoexec.ash, you still need sd card.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
