sbt
- Nov 12, 2016
- Australia
- SG9665GC v2
So have this issue since I got my SG9665GC last year; I have not been able to reliably read micro SD cards (either the supplied 32GB card, or any other) using this plug in card reader supplied with the dash cam. It's the one with both SD and MicroSD slots, and USB on one end and USB OTG micro-b on the other. I've tried in three different USB slots on one Mac, and the only available slot on another. I put it aside and started using an SD slot adapter with the Macs instead. However, I'd like to able to use this with the OTG end.
In MacOS, if I try to copy videos from the card to the mac, it starts out OK, but after a minute or less, the copy will stall and error messages start to pop up, such as "disc not ejected properly". The syslog includes the following (many dupes elided):
Once this happens, any files not already copied won't make it across and I have to unplug the reader to get things back to normal.
I haven't any other reports of issues with Macs, and only other thread from late 2015 where a user reported speed issues with their reader (but not the same symptoms as this issue).
Have I a dud, or am I doing it wrong?
Cheers,
Sam.
Code:
2017/01/05 15:27:58.000 kernel[0]: USB device AAAA8816FD131000 - BOT reset completed with kUSBHostReturnPipeStalled.
2017/01/05 15:27:58.000 kernel[0]: USB device AAAA8816FD131000 - will be reset!
2017/01/05 15:27:58.000 kernel[0]: USBMSC Identifier (non-unique): 0x00000000 0xaaaa 0x8816 0x1308, 2
2017/01/05 15:27:58.000 kernel[0]: USB device AAAA8816FD131000 - fConsecutiveResetCount = 1.
2017/01/05 15:27:58.000 kernel[0]: disk6s1: media is not present.
2017/01/05 15:28:28.000 kernel[0]: USB device AAAA8816FD131000 - BOT reset completed with kUSBHostReturnPipeStalled.
2017/01/05 15:28:28.000 kernel[0]: USB device AAAA8816FD131000 - will be reset!
2017/01/05 15:28:28.000 kernel[0]: USBMSC Identifier (non-unique): 0x00000000 0xaaaa 0x8816 0x1308, 2
2017/01/05 15:28:28.000 kernel[0]: USB device AAAA8816FD131000 - fConsecutiveResetCount = 1.
2017/01/05 15:28:28.000 kernel[0]: disk6s1: I/O error.
2017/01/05 15:28:28.000 kernel[0]: disk6s1: media is not present.
Cheers,
Sam.
