Car battery keeps dying
have followed up via private message already
OK, would be interesting to know what went wrong with hardwiring.
In additiona to earlier posts the solution was actually given by installer.
The installer was saying the problem was my car only had an option of keeping the camera on 24/7 or off.
I think your isntaller meant @ "... or off" when car ignition is off, then dahscam is also off. This is the right solution.
You need to find the issue with the installation.
Every car has switched fuse.
Please ask your installer to use 2nd option of hardwiring "of keeping off", - thats the switched fuse. After you turn off ignition, dashcam going to turn off.
He has it wired to run 24/7 at the moment
yeah, thats is seen from OP complaint. Don't know if he meant to do so, or installer didn't know exact needs. Probably miscommunication, but I am sure there is a simple solution.
