Thank you jokiin for sharing your thoughts... mine are the same as yours:
- freaking weak battery (from full charge to zero in less than 2 minutes);
- Around 10 minutes for the GPS start recording;
- The sounds that you can´t turn it off (FIXED);
- No custom image (FIXED).
I´d like to share my thoughts on Cambox firmware: just awesome! Thank you tmanz for sharing it!!
The image quality was improved by almost 100%. The bitrate is really higher, as you can compare at the asphalt of the next images (no treatment, it´s a
1:1 Registrator View region crop from the 2304x1296 footage):
Before:
After
There´s still some noise, even during daylight, but the plates don´t flick anymore..
For the quality, really worth to try it, jokiin.
Only have one major problem: Now I can´t turn it on after connecting to the computer, because the battery won´t charge anymore.... if I unplug it, it just give me around 5 seconds or so..
If someone that has the technical knowledge to check the both firmwares, and fix this, would be much appreciated..
