Telling people to "Try to understand" is just as bad.
You're the second person to be condescending instead of helpful. Why?
1. Download https://www.dropbox.com/s/zcvlgq0xni91l2z/autoexec.ash?dl=0
2. Delete everything in that file (not explained anywhere above to delete and replace, by the way!)
3. Made sure last line was a blank space.
4. Made sure to save as UNIX and not UTF-8 code.
3. Insert SD card into camera and reboot camera (also not mentioned above)
4. Removed Yi Action for ios
5. Rebooted phone
6. Reinstalled Yi Action for ios
7. Rebooted phone
8. Connect to yi wifi
9. Open yi action
10. App is still in Chinese.
How about confirming if I'm doing something wrong instead of telling people they are stupid.
To those who have never written a script...
I got this to work after a failure using Windows 7, but I never did understand what people meant by leave the last line blank.
It also is not clear to me why someone uploaded a file that has the wrong script and left instructions instead of uploading a working file
What worked is:
Load Pspad (free) so you can see if you are unix format or not (supposed to be unix). It should say unix on the bottom. I tried using notepad the first failed time so maybe somehow Pspad is better.
Download and copy the drop box file (earlier in thread) to a mini SD card.
Open it on the card using Pspad
Copy:
#paste your desired sn below
test board config psn Z23L545AUS0838883
and paste it over the existing text, being careful not to disturb the mysterious "empty last line" by highlighting only the text you are replacing (if you look after the text ends aren't last lines always empty? Is there a special procedure for inserting an "empty line"?
Save
Uninstall Yi Action from phone and reboot. Start up the phone and reload Yi Action
Put the mini SD in the Yi. Start up the Yi and the blue ring on the front will blink, and not go solid.
Turn off Yi and restart it. If yours acts like mine the blue ring will now go solid. Turn on wi-fi
Connect the cell to the Yi wifi. It should show as a new network and you again enter the Yi password 1234567890
Worked for me.
If anyone can explain the last line blank thing I would be obliged.
I just got my new Yi Action Camera.
Immediately after connecting the iPhone to the camera the UI is changing from English to Chinese.
Looking for instruction ow to correct the above.
I think there is a brand new Yi 2. Mine is the original (I paid $70), it does 1080 60p and I think 2K 30pWere you able to change the language to English? Is your camera the Yi 4k?
Nice! Thanks. Now it should be easy for people unused to hacking who ordered not realizing there was an issue with non-international YisIm just adding correct file
https://www.dropbox.com/s/nxk4bkhrgc2cxb7/autoexec.ash?dl=0
