I just fixed it. I loaded a new firmware, ver. 2113.1112.18. You know it's different as there is a new category called PLATE NUMBER, and it also reboots into Chinese.
The other thing I did was to make the settings I wanted (No g-force, 3 minute screen saver, etc), and then instead of powering off the car, I hit the power button for 3 seconds, and let it do a proper boot down sequence. Then I powered it up, and all the settings were saved. The corrupt final file issue is also fixed. It was the firmware FW96650A.bin.
When I shut off the car now with the key, the screen also shows a 'Goodbye' splash screen, which the previous FW version did not do.
Remember, after you flash the FW, take the card out, format it in your computer, then insert it back into the cam, or else you will flash the cam everytime it boots.
Maybe the 12 second videos are when you turn on your key for just a short time? Or a loose connection? I do not think I have experienced that problem. But I have mine set to the longest loop. (5 minutes I think).
What purpose does motion detection serve, if the camera is supposed to be recording anyway? Is this for "parking mode"
Still no joy, can't get it back to life. When I remove the charger, the flash light blinks very fast for a couple of times. I think it's dead.Since the last couple of weeks, my cam didn't start when I turned on ignition. However, when I plugged the power cable out and in again, the cam started working. But now it's completely dead. I took it apart, and checked it with a multimeter and there's 5V on the capacitor (and when you turn off the power it slowly decreases) so I don't think it's a power problem.
Does this sound familiar and can I throw this thing away or is there something I can do?
It wasn't as good as I hoped for when I bought it. It didn't shutdown properly, it didn't saved the date and license plate info, etc etc.
So, is it worth to buy the G1W-C again? Was it just me with this monday morning device?How are everyone's units functioning? Or is it better to buy the normal battery version? I think that one will stop functioning soon with the high car temps (+50 degrees Celsius)
On a G1W it's the Mode button (lower right one).
Like the nickname ;-)
