Constant beeping
Sam Brown
Lanark
Hi there,purchased my 522 about 14 months ago and this morning i switched it on and its just continual beeping! No picture, just continual beeping... has anyone experienced this! And more importantly,is there a fix! I press the re-set button but as soon as you switch back on this beeping comes on and you cant hold the button to switch the unit off because its as if its frozen!, Only way to shut it down is just hit the reset button and it shuts down, but like i said,if you then switch it back on the continual beeping re-starts
Welcome to DCT @Sam Brown :)
You might get a faster and better response in the 522 forum HERE
I don't have this cam but continuous beeping with most dashcams indicates an SD card problem,
I actually took the SD card out Phil thinking it could be that but didn't make any difference... but thanks for your input m8
