heiNey said:do you just copy the 'BlackVue' folder to the microsd card and put it into the camera? what configuration settings do you guys use?
gd_low said:mio,
Pm sent . thank you
gd_low
[version-1.1.1a]
# Custom config file
# ------ Voice = "KOR/RUS/ENG/FR"
Voice=ENG
# ---------- Play Volume
Volume=95%
# ---------- Priority of the main processes
priority=20
# Set LED's (ON/OFF)
# Wi-Fi LED in normal mode
wfled1=ON
# Wi-Fi LED in parking mode
wfled2=ON
# GPS LED in normal mode
gpsled1=ON
# GPS LED in parking mode
gpsled2=ON
# Set G-sensor value (Low/Normal/High/ST)
# G-sensor in Normal mode
gNormal=ST
# G-sensor in Parking mode
gPark=ST
# Set Video parameters
# 0 = standard avserver
# 1 = via avserver.sh in BlackVue/Config
# 2 = custom: AEC/AGG with AWB TI2A
Video=2
Size=1080P
Bitrate=15000000
Cabac=Yes
# Auto White Balance (Custom/Normal)
# Custom - custom AWB
# Normal - standard avserver AWB
AWB=Custom
# AWB Sensor (1...3): from "warm" to "cold"
AWBS=2
# Daytime Brightness (1....7)
AECB=3
# Auto Expositure Speed (1...4)
AGGS=2
# Night Brightness (1....7)
AGGN=3
Mio said:Guys, how the exposure?
Why all the are silent?
Good or bad?
Hillbilly said:heiNey said:do you just copy the 'BlackVue' folder to the microsd card and put it into the camera? what configuration settings do you guys use?
Yes you do Then open the viewer and play with the setting to your satisfaction
Mio said:Nothing delete, and rename not need to
I wrote above.
heiNey said:Mio said:Nothing delete, and rename not need to
I wrote above.
great. thanks. i'll try it out later and see how it is.
i cant seem to figure out how to change the date/time on this. its showing as january 1, 1970, and the time isnt right either. i set my timezone to los angeles, ca, but its still not right.
Mio said:I'm sorry, I forgot to change
if you insert a blank USB flash drive, will be the time zone
or here
http://yadi.sk/d/Xm5zamLc36rqO - Europe
