mpmetro
What combination of buttons did you have to push to get the GS520 in DirectUSB mode? Which 0803 elf did you use? I see two of them. I'm trying to find the autoexec.ash file, and I found a few but I'm not sure which one to use.
ok button + plugging in USB gets the gs520 into directUSB mode. I do a press of the reset button before just to make sure its not in some other weird mode.
I used this version: https://dashcamtalk.com/cams/mini0803/0803_20140507-GPS-1CARD.zip
This is the autoexec.ash I used (https://dashcamtalk.com/cams/Backup autoexec.ash.zip)
After loading this .elf, press reset button, then try turning on. Screen will show white, but then may turn off while loading the firmware. Wait about 5 min or less then reset again. (5 min is just an arbitrary number, it could have completed in probably less than a minute, but just to be sure, I waited) Also make sure battery is fully charged. For some reason I couldnt do it while plugged into a usb charger, as it would automatically keep going into usb file transfer mode even though i'm not connected to a computer.
