raspberry01
Hello, I have the A129 Plus Duo and I purchased a hardwire kit to install along with it for parking mode. Everything seems to have worked fine once I finished, except the dashcam is only powered for the the first one or two times I start my car. By that I mean, my car is off initially while I installed it, then I started the engine to see everything working, when I turn off the engine, the REC led starts blinking indicating parking mode is working correctly. Then it continues working after I start my engine again but if I turn off the engine this time, the dashcam will stay off and will not power on again. The only way I've managed to get it working again, is to unplug the fuse taps I added and plug them back in. Then it will be able to draw power but then the same thing happens all over. More specifically, it seems to be the always-on (batt) fuse tap that I have to reconnect for it to start working again. I initially only unplugged the acc fuse tap and plugged it back it, started the engine, still no power. But after I unplugged and plugged the batt fuse tap, it started working again. It confuses me because I thought the acc fuse tap is meant to power the dashcam when the engine is on.
Does anyone have any idea as to why this is happening?
