dashcam no longer working correctly through GPS mount
stuckintheoffice
Having solved the memory card problem, my A119 dashcam was working great until...
Randomly, during a long motorway drive, I started hearing the startup noise it makes. A while later, it did it again...and then again. Bascially it seem to be restarting intermittently.
I had a look at the footage when I got home and some of the files are corrupted. Others work fine. I assume, but don't know, that the corrupted files are when the restart problem was occuring (everything looks a bit the same on the motorway!).
I took the power lead out the GPS port and instead put it straight into the camera, and it works fine this way. But isnt ideal as I don't have any location or speed information.
I've only had the camera for six months, do I need a replacement GPS unit?
LateralNW
You should have gps info embedded in the file. Others have said your work around does still power the gps unit.
Re the question of a return others on here are better able to answer.
CaptureYourAction
Retailer
New England
DOD, Dome Technologies, VicoVation, Viofo, GitUp
GPS should still function when powering the camera directly.
S
stuckintheoffice
Hi
Many thanks for the replies. I've had another look and there is no speed information or GPS location to be seen :-(
