No, time-lapse video only records video but the Mobius also has a Time-Lapse Photo functionality in the Photo Mode.Time-lapse video, just so i understand correctly does it still record video and then just save screenshots at the same time ?
Thank youWelcome @failmenot
All 3 models, Mobius 1, 2 and Mini, have that feature.Thank you kindly, will any mobius do or is there a specific model you would recommend?
The eBay sellers aren't that informative on all options and settings.
I think loop recording is deactivated by default when you enable time lapse video.I recently tested my Mobius 1 with time lapse video (1080p at 0.5s intervals). I found that when the card became full, it did not delete the oldest file and continue, which I would expect with loop recording enabled. I have not tried it with different intervals to see if that makes a difference.
I reported it at RC Groups but got no response - I might try again.
No, I think the GUI let me have both enabled at the same time. But perhaps I need to try again with different settings.I think loop recording is deactivated by default when you enable time lapse video.
Just because the GUI let's you enable it that doesn't mean it's actually working. I'm also not sure, I'm just going with the tip's info that says the max. file size when in time lapse mode is 4GB, which indicates no loop recording.No, I think the GUI let me have both enabled at the same time. But perhaps I need to try again with different settings.
@Isoprop has the GUI fairly well sorted by not allowing the user to set conflicting parameters. Perhaps this is one little thing that slipped through. I was thinking of using Mode1 for driving, then switch to time-lapse video in Mode2 when parked. But that's no good as the card is nearly always full of video clips, with just enough space for one more clip. When I tried the camera in time-lapse with only a small amount of capacity left, it saved only the last and first frame. It then continued to flash the led indicator without actually recording anything.Just because the GUI let's you enable it that doesn't mean it's actually working. I'm also not sure, I'm just going with the tip's info that says the max. file size when in time lapse mode is 4GB, which indicates no loop recording.
F | Dashcam with cabin camera for summer road trip | What Should I Buy? | 3 | |
B | DashCam Recommendations UK | What Should I Buy? | 3 | |
4K dashcam Recommendation | What Should I Buy? | 11 | ||
Dashcam for Bicycle? | What Should I Buy? | 27 | ||
Rear view mirror dashcam recommendations or stick with standard cams? | What Should I Buy? | 10 |
