DDPai M6+ not waking up from parking mode
iduk
My DDPai M6+ is not waking up from parking mode unless I remove power and put power back to it. When in parking mode the system shows single red light indicating power is not an issue. I have tried tapping in to activate the G sensor and this failed. I have tried different cables and memory cards, still same issue. I love this cam but this is a pain in the rear end. Any suggestions welcome
Billaboard
I assume you have read my recent thread about parking mode. I'm now fairly sure the problem was caused by the failing car 12v to 5v plug in adapter - the one supplied with the M6+. Leaving it powered on a new adapter together with a bit of fiddling with the parking mode timing settings seems to have it working again.
If you use one of these plugs, I cannot speak too highly of the one I replaced it with, which shows the current the cam is taking. It definitely caught my failing camera battery before it caused a possible catastrophe.
Similar threads
