Mtz
- Nov 15, 2012
- Nice place
- Romania
- Viofo A229 Pro TeleQuad
I think the shielding and heat sinking is built into the PCB, you can see the big heat transfer pads for transferring the heat into the, err, I think Canon would call it a magnesium alloy chassis - you don't normally see things like that in action camerasLooks nicely put together. I like the heat sink, but no shielding on CMOS?
Hi Mtz, can you tell if the lenses are glued in, can they be removed for aftermarket lenses?[/QUOTE
I should Not get excited, and read everything first before I say anything. This was a message to myself!
If you look around the base of the threads, you can see the glue they used to hold it in place. Holder looks similar to the A119.Hi Mtz, can you tell if the lenses are glued in, can they be removed for aftermarket lenses?
It's a Sony IMX317. The same sensor and A12 chipset is found in the Xiaomi Mijia Mini action camera.Anyone have a link to the camera sensor used in the F1?
Note the big pixel size, for a 4K action camera sized sensorIt's a Sony IMX317. The same sensor and A12 chipset is found in the Xiaomi Mijia Mini action camera.
Extract from http://www.sony-semicon.co.jp/products_en/IS/sensor2/products/index.html
The sensor supports on-chip HDR, but it's not implemented yet as that needs support from Ambarella.It's a Sony IMX317. The same sensor and A12 chipset is found in the Xiaomi Mijia Mini action camera.
I'll upload some footage when I get my F1need more footage on youtube from those test sample cameras out there.
That's a shame. I suppose that applies to quite a few of the test cameras out there.My test camera does not have the final lens version.
enjoy,
Mtz
Gitup F1C Non-Loop Recording | F1 | 1 | ||
Z | F1 & Samsung S9 and GitUp App | F1 | 13 | |
GitUp F1C 4K - First Impressions | F1 | 17 | ||
GitUp F1C - 4K F1.8 130° FOV | F1 | 113 | ||
GitUp F1 - Battery and Charger | F1 | 0 |
