Аn unofficial version of the june firmware - https://copy.com/q0hTJHmlcEC9
Not checked, can cause problems.
dashuser said:I'm not sure if this is just a trick or the video really has 60 fps.
Could someone please explain me why do you want to use 60fps? Whats the advantage of 60fps?
How does the motion detection (parking mode) work? Is this automatic, or do you need to manually control it to put it into this mode each time you want it to operate while parked?
Motion detection can be activated manually from menu.
There are only very few dash cameras out there which goes automatically into parking mode ( motion detection ) mode after ignition switched off. For this you need to hardwire dash camera.
The only one with this function I have tested is Urive Albatross II. There are few more on Korean market, but they are not yet widely introduced to outside Korea public.
Thanks! How does it work manually putting it into parking mode if at that time the power is turned off?.
Approximately how many hours/minutes does the 32gb card store? I understand 32gb is the limit, but also that the LS300W has a high bit rate and therefore high file size...
32gb holds in total about 2.5h 1080p 30fps 15Mbps.
NT96650 + Ar0330 based dash cameras can also record to 64Gb memoty cards.
Thanks - do you know how this works if, say I go on a 3h trip? It will record a 2.5hr trip, but then the card will be full... so it will delete that and I'll have a 30 min video when done. Is that correct?
