pao3007
Hi, I bought 322GW few days ago, was working fine for 3 days, after firmware update through my android smartphone the problems started. After it restarted after firmware update It said that I need to format my SD card (why?) so I took out my SD card from Dash cam and moved few video files to my computer, to save them, and formatted SD card in my PC, afterwards I put formatted SD card back into my dashcam and It said somthing like "SD card error, need to be formated..." so now I tried formate my SD card via Dashcam but it failed to format it and said that I need "Class 10 or better SD card", I have Kingston 64GB Canvas Go! Plus U3 (U3 is recommended for use in dashcams), so its better that Class 10. After Trying several times It didn't show any error so I tested it out, I started car, dashcam turned on and started recording, I let it be for 5 minutes and turned off car. On second test dash cam turned on and started recording for 2 to 5 seconds and immidiately stopped recording, tried manually starting recording but again it stopped after few seconds. I tried brand new SD Card which was bough to be used in another car with same 322GW dashcam but again same thing. Dashcam was working for 3 days with "stock" firmware without any problem. Thanks
ah and sometimes after firmware update it freezed when trying to play recording or suddenly in middle of recording (in case when it was recording more that few seconds)
