troels
- Jun 29, 2016
- Australia
Hi all. Just received two units and have been trying them out before installing.
I have installed the latest firmware posted recently.
I have an issue whereby at the recording screen, during recording I press the REC - the unit the starts to do a continued double-beep and the REC button flashes. This is presumably to warn me it is not recording? At this point I believe I should be able to go into playback mode.
This worked a few times but then it stopped - it now just continues double-beeping and none of the buttons have any affect except the power button which turns off the screen.
After a power-cycle I am at the recording screen again, REC is red (not flashing or beeping), the unit does not appear to be recording. Pressing Menu does a screenshot, and MIC button toggles audio recording. Press REC gets me back into double-beep mode again. Basically I can’t get out of this.
This happens on both units and also occurred before I upgraded the firmware. Upgrading the firmware (again) was the only way to get out of this mode but it still happens again during use after the upgrade. I have also tried multiple different 64GB micro SD cards - same behaviour. Both cards were formatted in the cam, although the format was extremely quick (does this sound right?).
Unless I'm doing something wrong then it looks like there is a fault with these units. Not a good start - I read good things about this cam but these are failing at the first hurdle.
Any idea what is going on?
