As I said before, that is how the camera is supposed to operate. It will beep when you stop the recording or start camera without a memory card. This is to alert you that is not recording.
NormalI put my old Kingston SD without "memory error" massage (cam can format it and works) and problem still exist, noisy beeps when I am trying to interupt record by rec button or menu button,
Class 10 SD card required according to Voifo.What write and read of SD parameters I should looking for that resolutions: 1920*1080 60fps movies or 2560x1440 movies ?
Are you saying the camera won't format the card? Otherwise, the camera will properly format the card.CaptureYA, I think u re right ! Problem is in my SD, could u give me info how to format 64 GB SD to fat32 (I use guiformat-x64 software)
What parameters of allocation unit size I should do?
What brand card is it? You said your Kingston formats fine though right?cam allowed formating the same card before upgrade firmware up to 2.0 ver
The camera freezes on boot up even without a memory card inserted?I have a similar issue but can't reset the camera to defaults. Was using 1440p@30 with 5 min looping, getting the dreaded boot freeze noise, but removing the card or not the reset button doesn't seem to be working.
It was running fine for around 6 weeks.
64 gb class 10 samsung card formatted using sdcard.orgs formatter then formatted in camera.
I did buy it via amazon so I have a hassle free return option, but would prefer to fix it.
A119 beeps and errors constantly now | A119 | 14 | ||
E | A119 will stop recording mid drive (sometimes beeps, sometimes doesn't) | A119 | 21 | |
D | Double checking on A119 SD Card please | A119 | 7 | |
Double image. | A119 | 8 | ||
R | 20 min into record I get a double beep - what does that mean? | A119 | 24 |
