English Firmware for 70Mai A500s
I copied firmware 1.0.17ww into SD card and powered on the camera, it automatically detects the firmware and applies the file.
I have a 70mai dash cam pro A500s and have Chinese language and located out of China and cannot connect to the Mobile as well, please help in changing the firmware to English firmware, however, my version is 1.1.17 as attached
For WW version A500s (70mai Dash Cam Pro Plus+)
[not A500]
Version: 1.0.2ww
Download:
How to:
Unpack the archive. Firmware from the archive "FW96580A.bin " copy to the microsd in the root of the memory card and insert it into the recorder when it is turned off. Next, insert the power and DO NOT press any buttons, and wait for 30-40 seconds. During the update, there will be no messages on the screen about the update, only the LED will light up blue and then red.
if we not used existing SD Card with "root directory" , How to flash it with new Firmware . Please
No way. What is the problem with copying a file to a memory card?
Hi @lisabon_Q3
I got a 70mai a500s pro plus chinese version and I downloaded this global version but the app says "wrong region, contact your seller."
Is this issue a known one? Thanks.
Also, I recently realised that my SD card is not being emptied automatically and it fills up pretty fast too.
this is my firmware:
Which version of the app informs you about this?
If you have installed firmware 1.0.17ww on the Chinese version, then you need to use the 70mai international app from the app store.
@lisabon_Q3 my device was chinese at first then I downloaded 1.0.17ww, the app is 70mai app from google play and it is currently in version 3.4.3. Thank you
You have the Chinese version of the 70mai app (v.3.4.3) . To work with A500s with international firmware 1.0.17ww, an international application 70mai is required (v. 3.5.5).
@lisabon_Q3 thanks for the swift reply! I downloaded the apk but I still get this error:
I wonder if I should reformat my device just in case I got the wrong firmware
@lisabon_Q3 Thank you for all the help, my version was 1.0.2ww not 1.0.17 so that was the issue. I got it all sorted out now after a while. Thank you once again.
Maybe 1.0.17ww?...
Previously my device was running version 1.1... ww . I don't remember exactly. There were some functions that worked ok, then when I updated to 1.5 it lost that function. I want to go back to the old version. i tried version 1.1.20ww but it's still the same. So I want to try installing version 1.1.17ww
Firmware 1.1.17ww does not exist for download.
Hello,
Does anyone have firmware version 1.4.24ww 70mai for pro plus+ ?
I have been trying to flash and re-flash the firmware in my dashcam with whatever ww version I could find in the internet, but my dashcam screen is still always black eventhough the indicator light is solid blue.
Any kind of help is appreciated, thank you.
The latest firmware for the worldwide version A500S-1 dashcam seems to be v1.5.27ww. This is the version that I have in my dashcam unit right now.
