Schizophonic
- Apr 24, 2016
- United Kingdom
Just want to see what else people think before going through Thinkware UK support.
The device was running fine and recording till about a month ago, it wasn't until recently I wanted to extra some data and noticed the footage was not on the memory card.
The first thing I noticed was that annoying voice not coming on when I turn the car on, it doesn't tell me how many 'incidents' it picked up and I thought I turned the voice off or turn it down.
The next thing was that I tried to pair up my mobile app with the device and once it picked up the wifi and connected the app kept telling me that 'inactive connection for 2 mins, connection closing' at that point it then my app kicks me out and I'm not making any connection to check any of the settings.
So come today when I get more time, to do more testing and fault finding I try to format my Thinkware MicroSD card and plug it into the device it behaves normal but after a bit of time I check the contents and its not recorded anything. I try to do a hard reset on the device or force format the device (using the format button) but no sign of the device performing anything.
I have updated the firmware before and tried to put the update files on the memory card, loaded it in the device and it said it found an update file and will update the system files. I let it do thing hoping it would clear up the bugs but nothings changed.
So it leads to me being the memory card issue, I grabbed an 1GB micro SD card, format it and same thing happened. When the memory card is empty it tells me memory card not suitable, resetting device and goes in a loop.
Now I can get another Micro SD card but its one of the things to test soon.
Is my device broken? Can you suggest what else to test?
