F770 DAB interference
Keiths
Already posted below in alignment question.
Just another request.
If I’m only having a 1ch front unit, will I avoid DAB interference issues?
Maddog1974
Retailer
Colchester, Essex
Thinkware Q800 Pro Front & Rear
99% of the time with Thinkware you don't get any DAB interference anyway but we do get the odd vehicle that does. Again of these most are caused by the rear camera or rear camera cable being too close the the actual DAB antenna of the vehicle and can usually be sorted by running wires the opposite side of the car or using a Ferrite Clip or 2.
K
Keiths
Many thanks for your prompt response to both questions.
Am I right in thinking in terms of the LDWS FCWS most switch these off. And whilst I have a Road Angel Pure for best camera protection, I’m thinking the speed camera data is probably worth leaving on, or is it the case that that switches off with the other alert functions?
A13x
I have installed so many thinkware camera the issue you are having is the wires and where aerial is. normally it's in or near back window. the rear cable and camera if fed to here may interfere with the radio.
Maddog1974
Retailer
Colchester, Essex
It really is personal choice, personally i have everything turned off apart from the Fixed Cameras (I have mobile zones turned off) in my old Smart Car i used Lane Departure warning but my newer one has that factory fitted so i don't now. You can just have the Camera warnings on with the rest turned off though.
S F770 2
K F770 2
K F770 1
Jack Daniel F770 0
R F770 2
Similar threads
