- Nov 25, 2013
- Shenzhen
- China
- B1W/B2W/B2K/B4K/DV688/DV988/B1M/B2M
Hopefully soon!
cardvr_img.bin
![drive.google.com](/forum/proxy.php?image=https%3A%2F%2Fssl.gstatic.com%2Fimages%2Fbranding%2Fproduct%2F1x%2Fdrive_2020q4_32dp.png&hash=e84dc8abb4ffb7508216aee07361dec4&return_error=1)
Hopefully soon!
Check the version info in the APPI formatted the card again. Added the attached file to the root and connected it back up. Is there any audible notification that the firmwars has been upgraded?
I just went to check, tried to connect via wifi and the camera switched off. Unplugged it and plugged it back in several time and I get no lights at allCheck the version info in the APP
I think there's a recovery process for these if it has, @estore009 will be able to help you outI just went to check, tried to connect via wifi and the camera switched off. Unplugged it and plugged it back in several time and I get no lights at all
Hope it's not bricked!
Yes it is.We're connected! Firmware is now BSSC04.200622.V1 is that correct @estore009 ?
It will auto-reset when the dashcam detects a slow speed card for the first time; if it keeps saying slow speed card after reset, you have to change a new card or format fully the card on a computer!Excellent I'll see how I go.
Change to a new card?Still resets a lot with the low speed warning.
You can give it a try also!Seems like my 64gb card is working OK. Do I need to revert back to the previous firmware if I'm not getting the slow SD card warning now?
No updated firmware version for parking mode. Use this 20180528s firmware if you hardwired the dashcam!I just need to know what the latest firmware is for parking mode
Is that the standard firmware? I have mine hardwired so it's always on. Which firmware switches to a lower resolution filming when parked then back to full resolution once moving?No updated firmware version for parking mode. Use this 20180528s firmware if you hardwired the dashcam!
This 20180528s is the standard parking mode firmware!Is that the standard firmware?
This low bitrates parking mode does not work well according to our tester. I do not recommend it to you!Which firmware switches to a lower resolution filming when parked then back to full resolution once moving?
No problemThis 20180528s is the standard parking mode firmware!
Ah ok good to know!This 20180528s is the standard parking mode firmware!
