What I miss is the possibility of playback and the ability to protect or remove clips on the camera. The novatek does it on other cams so I guess it's a design choice.
Using it as a cardreader is possible but what "it's not designed todo this" means I don't know. It complains about low battery (ironically because of the capacitor) when connected to a PC, but it does work for copying files.
I know its not straightforward being a Linux user but I'd suggest trying the newer version as we have made some image quality adjustments and see how you go in those difficult lighting situationsOn beta 20151230.v2
Jup worked on the laptop.
Will be testing 20160111.v2 tomorrow.
Strange thing, the releasenotes say that beta4 is dated december 17th, while beta3 is december 31st...
Any more hints about changes made in this beta?
can you roll back to previous version and check again?
also can you double check lens or window has no fingerprints or similar
Ah wait. my bad. The upgrade resets all the settings to factory, and I was running at -2/3EV before....![]()
No problem, happens.Ah wait. my bad. The upgrade resets all the settings to factory, and I was running at -2/3EV before....![]()
Difficult lighting conditions but I guess this could really be improved, I have not seen this much glare in other cams.
